2 - Selecting a Project
ProjectWise / Web Portal Licensing Landing Page
Once you have signed into the CONNECT Portal using your Bentley CONNECT account, select your project from the Recent Projects tile, or select the View More Projects icon to see a list of all available projects.
When you select your project, the Project Portal opens. From the ProjectWise Connection Services pane, click the Share tile.
The ProjectWise Share Work Area opens. From this page, you can access the contents of your Project Share. You can create and manage connections to repositories and view the contents of those repositories. For more information, see the Work Area Access topic.
Other Language Sources
Deutsch
