3 - Accessing the SharePoint Connection
ProjectWise / Web Portal Licensing Landing Page
From the left pane of ProjectWise Share, you can access your share and the connections to the repositories you created.
Under Share, select All to see all the items stored in your Project Share. Select In Progress to see any files which are currently being uploaded to the Project Share. Select Recycle Bin to see files which have been deleted from the Project Share.
The left pane also displays any connections to repositories which you have created, giving you quick access to your repositories. To edit or remove a connection, or create a new connection, click the Manage Connections button at the bottom of the left pane.
To Access your SharePoint Site Library content, click on the SharePoint Site Library connection on the left and navigate through your SharePoint Site Library folders. Content can be downloaded, uploaded and Open in SharePoint.
Other Language Sources
Deutsch
