1 - Creating a New Connection to a Repository
To view files stored in a SharePoint Site Library, you need to set up a connection to the SharePoint repository.
Only Office 365 SharePoint Sites are supported.
  1. From the Manage Connections page, click New Connection.
  2. In the Create New Connection dialog that opens, enter a name for your connection in the Connection Name field.
  3. From the Repository Type dropdown, select the type of repository to which you want to connect.  Additional fields display in the Create New Connection dialog.
  4. In the Repository Type, select SharePoint and click on Sign in with Microsoft.
  5. Microsoft's online authentication dialog opens. Enter your company credentials to get your SharePoint Site Library list.
    (This only needs to be done once. If you cannot authenticate, contact your SharePoint Site Administrator.)
  6. From the SharePoint Site library dropdown, select the desired SharePoint Site. Only sites that you have permission to access are listed.
  7. Once the site is selected, click Connect and the Connection is created. The name of the connection displays in the Manage Connections list.
When you create a connection, the name of the connection displays in the left pane of the ProjectWise Share Work Area. To view this, go back to the SharePoint Site Library by selecting ProjectWise Share in the top left. The ProjectWise Share page displays. To open the repository to which you have connected, select the name of the connection in the left pane.
Other Language Sources
Deutsch
