ProjectWise / Web Portal Licensing Landing Page
From the Manage Connections page, click the Edit icon. The Edit Connection dialog displays.
Edit the Name and click Update to save your edits.
From the Manage Connections page, click the Delete icon. The Delete Connection dialog displays.
If you are sure you want to delete the connection, click Delete and the Connection is deleted and no longer displays in the Manage Connections list.
Other Language Sources
