Subscription Entitlement Service versions of Hydraulics and Hydrology Products (i.e. OpenFlows) replace the Municipal License Administrator with a Feature Level Selector dialog and utility. To learn more, please refer to the following wikis:
Setting the License Feature Level in the Feature Level Selector
Setting the Feature Level via command line for one or more Windows accounts
Licensing OpenFlows | Hydraulics and Hydrology products - CONNECT Licensing
Other Language Sources
