| Product(s): | OpenRail Designer |
| Version(s): | 10.00+ |
| Area: | Geometry |
This video will show how to 'merge' or combine DGN files that contain civil data. Generally we suggest working with a federated workflow. However, sometimes there is a need for users to work simultaneously to create geometry in separate DGN files then combine it into 1 geometry DGN.
