| Product(s): | OpenRoads Designer, OpenRail Designer, OpenSite Designer |
| Version(s): | 10.08 only |
| Area: | General |
NOTE: For versions 10.09+, the Version Checker was replaced with the Civil File Manager. To learn more, click here.
This video explains the circumstances behind the "Incompatible Civil Data" message and demonstrates using the VersionChecker.exe tool to associate a DGN file to its desired civil product.
When opening a DGN in OpenRoads Designer, OpenRail Designer, or OpenSite Designer, the DGN is 'aligned' to the product, so if the DGN will need to be opened in another product, it may be necessary to re-align the DGN to the desired product.
NOTE: DGN files from any product can be referenced into a different product for use by the programs. Product Alignment is only necessary to edit the files.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
