CONNECTION Client Recommends Update for Version Already Installed
Product(s):CONNECTION Client
Version(s):All
Area:Updates
The CONNECTION Client recommends an update for the version that is already installed.
This typically means there's an issue in the registry with the installation. To resolve uninstall and reinstall the CONNECTION Client.
NOTE:
CONNECTION Client update needs to be performed on the local Windows administrator account, not by providing the administrator's credentials on a non-Administrator account - see: CONNECTION Client update fails or causes sign in issues if user doesn't have local admin rights
Installation - Manual - Licensing, Cloud and Web Services Wiki - Licensing, Cloud and Web Services - Bentley Communities
Other Language Sources
Deutsch
