| Version(s): | 10.10.01.03+ |
| Area: | Drawing Production |
| Original Author: | Holly Herring, Bentley Technical Support Group |
What are the Item Type variables?
This path points to the .json file. If you want to control it beyond the default location, use this variable. You do not need this variable for the workspace to function.
