Product Specific Licensing Landing Page
Note: This page is deprecated and will soon be removed. If you have questions about whether or not a specific product version supports Citrix, please refer the question to the Bentley product development team.
The following Bentley CONNECT Edition products have been validated for use with Citrix Applications and Citrix Desktop.
| Product Name | Versions validated | Comments |
| OpenCities Map Ultimate CONNECT Edition | 10.07.01.09 | |
| OpenCities Map Advanced CONNECT Edition | 10.07.01.09 | |
| OpenCities Map PowerView CONNECT Edition | 10.07.01.09 | |
| OpenUtilities Designer V8i SELECTseries4 | 08.11.09.879 | |
| PLAXIS 2D CONNECT Edition V21 Update 1 | 21.01.00.479 | |
| PLAXIS 3D CONNECT Edition V21 Update 1 | 21.01.00.479 | |
| PLAXIS Monopile Designer CONNECT Edition V21 Update 1 | 21.01.00.479 | |
| STAAD.Pro CONNECT Edition V22 Update 8 | 22.08.00.175 |
XenDesktop environment validated only. XenApp not validated. Check for Known Limitations |
| STAAD Foundation Advanced CONNECT Edition V9 Update 6 | 09.06.01.74 | |
| STAAD Advanced Concrete Design RCDC CONNECT Edition V11 | 11.01.00.180 | |
| MOSES CONNECT Edition V12 | 12.03.00.104 | tested in Citrix Workspace requires software support for OpenGL3.1 (e.g. MESA) may have ini files if installed locally also |
| MAXSURF CONNECT Edition V23 | 23.03.00.101 | tested in Citrix Workspace |
| SACS CONNECT Edition v15.1 | 15.01.00.01 | Tested in Citrix Workspace |
| RAM Structural System CONNECT Edition SES | 17.02.01.23 | Tested in Citrix Workspace |
| AutoPIPE CONNECT Edition v12.6 | 12.06.00.48 | Tested in Citrix Workspace |
| RAM Connection CONNECT Edition v.13.6 | 13.06.00.213 | Tested in Citrix Workspace |
| RAM Elements CONNECT Edition v.16.5 | 16.05.00.213 | Tested in Citrix Workspace |
