Subscription Services Portal Overview
 Product(s):Bentley Cloud Services
 Version(s):N\A
 Environment:N\A
 Area:Subscription Services Portal
 Subarea:N\A
Overview:
The Subscription Services Portal has been designed to support the CONNECTED Enterprise. A CONNECTED Enterprise is an Organization that uses CONNECT Edition versions to work within a Common Environment for Comprehensive Project Delivery. Within this Common Environment, CONNECTED Enterprises have seamless use of enterprise standards and content that will streamline support for the development, management, and communication of corporate knowledge across the enterprise.  The Subscription Services Portal provides data and Service paths to empower the Site Administrator to monitor, report, administer, and submit issues for their organization.  As the Subscription Services Portal evolves additional tiles and options may be included.
To access the Subscription Services Portal click on your company name in the top left corner.
Resources
The tiles available are broken down into two categories, Resources and Services & Standards.
Resources - These are common Services that any Administrator would potentially use on a daily basis.
Services & Standards - These are additional Services and Standards that will be available as the Subscription Services Portal expands.
Other Language Sources
Español, Deutsch
