Import xml File on Deployed Server
SELECTserver Licensing Landing Page
  Product(s): SELECTserver
  Version(s): N\A
  Environment:  N\A
  Area:  N\A
  Subarea:  N\A
  Original Author: Jutta Eisenhauer, Bentley Technical Support Group
How to update the SELECTserver licenses using an XML file?
Open Administration page
Windows Start – Programs – Bentley – SELECTserver – Admin page
Alternatively:
http://localhost/bss/admin/default.aspx
Copy the XML file into a folder inside the server.
Import the xml file in menu License Management > Import License File.
SELECTserver 8.x
SELECTserver 9.x
Select Browse... if you are using SELECTserver 8.x or Choose File for SELECTserver 9.x. and select the file that you copied on the folder.
Afterwards the Accept button must be activated to finish the Import successfully.
The file must not be unzipped, then HTTP Error 413.1 "Request Entity too large" occurs.
Other Languages Sources
Español
Deutsch
