| Bentley Applications | Minimum Version | Place | Upload |
| MicroStation CE Update 13 | 10.13.0.48 | X | X |
| OpenRail Designer | 10.7.0.56 | X | X |
| OpenRoads Designer | 10.7.0.56 | X | X |
| OpenSite Designer | 10.7.0.56 | X | X |
| LumenRT | 16.12.23.02 | X | X |
| OpenBuildings Designer | 10.0.5.49 | X | X |
| Bentley Substation | 10.5.0.35 | X | X |
| ConceptStation | 10.0.10.17 | X | X |
| Third-Party Supported Applications | Minimum Version | Add-in Link | Place | Load | Open |
| Revit | Versions Supported 2015-2023 | Download | X | X | X |
| Civil3D | Versions Supported 2018-2023 | X | X | ||
| AutoCAD | Versions Supported 2018-2023 | X | |||
| Inventor | Versions Supported 2017-2021 | Download | X | X | X |
Place – places the design file/component/model into an existing project in the design application
Load - loads the design file/component/model into an existing project in the design application
Open - opens the design file/component/model as standalone in design application to view or edit
| Portal Browsers Support |
| IE11 |
| Firefox |
| Chrome |
| Edge |
