Sign In
What is the purpose of this information?
Provides the process to sign in to the the CONNECTION Client, with or without having a password created.
*Please Note: Use the CONNECTED User - Individual User Process if you have not already Registered.
Step 1 - Sign in to the CONNECTION Client
After installing the CONNECTION Client, you will be prompted with the following dialog:
If you already created a password:
1. Enter your email address
2. Enter your password
3. Select Sign In
*Please Note: When a user signs into the CONNECTION Client initially, a security token is generated which is valid for seven days. Starting with CONNECTION Client 10.00.10.22, when this token is within one day of expiration the CONNECTION Client (if running) will now renew the token for another seven days to keep the user signed in. Users are strongly encouraged to upgrade to avoid signing in every seven days.
If you have not created a password:
  1. Select Forgot Password
  2. Enter the email used during Registration
  3. Check the I'm not a robot and click Send
4. Create your password and click Submit.
5. Sign in to the CONNECTION Client
Step 2 - Accept the Terms Of Service
When you sign in for the first time, you are required to accept the Terms of Service for using Bentley's Cloud applications and Services before proceeding. Scroll down to the bottom of the dialog box to accept the terms.
Other language sources
Deutsch
Spanish
