Bentley SELECT Open Access subscription provides subscribers with portfolio-wide access so you can employ the best and most appropriate mix of Bentley applications for any discipline and every project.
With SELECT Open Access, organisations of any size will save time, enjoy added flexibility, and benefit from reduced administration, with comprehensive usage reporting to manage licenses and costs. SELECT Open Access eliminates the purchasing barriers to the most effective software utilisation so that all Bentley applications are “instant-on” and at your service, so you don’t have to anticipate needs in advance - you can use any product available under the program that is not covered by your purchased licenses.
Any usage of Bentley applications in excess of your owned quantity is conveniently and automatically invoiced at the end of each calendar quarter (Term License(s), or TL, in short). In case of having the Cloud Service Subscription (CSS, in short), the account is invoiced at the end of each month.
In addition, SELECT Open Access provides on-demand and live training in the virtual classroom for new users through Bentley LEARN.
Main benefits:
The list of eligible software included in the SELECT Open Access program can be found on the Services Portal. Navigate to https://subscriptionservices.bentley.com/ and look for the "License Management" tile at the bottom of the page. Use the "Select" button on the tile to choose the "Product Eligibility" option. This will give you a PDF to download where you can see what licenses are available based on subscription type.
SELECT subscription, unlike SELECT Open Access, limits the licence portfolio to the purchased licences and a small subset of related and courtesy-granted SELECT entitlements. Otherwise, the SELECT programme retains the same benefits as the SELECT Open Access subscription.
Understanding why you received a TL Invoice
