| Version(s): | 10.00.00+ |
| Area: | Survey |
When multiple point curves are created in the fieldbook, the program will construct Bspline curves through the points. If the “Linear Feature Force Curves to Linestrings” setting is set to false, Bsplines will not be constructed and the program will create Line String.
Note: The two images attached show the same multiple curve.
Value = TRUE, creates a Bspline
Value = FASLE, creates as a Line String
