| Product(s): | CONNECTION Client | ||
| Version(s): | 11.00.05.42 | ||
| Area: | Installation |
When attempting to upgrade CONNECTION Client 11.00.05.42 to a later version, installation fails with the following error:
Another install in progress
A bug was discovered in this version that prevents updates from being installed from within CONNECTION Client. The bug was severe enough to necessitate pulling version 11.00.05.42 and replacing it with 11.00.05.43.
Please perform the following steps to manually apply a CONNECTION Client update to restore the in-product update functionality:
