| Product: | All SELECTserver Licensable Applications | ||
| Version: | Various | ||
| Area: | Activation | ||
| Subarea: | N/A |
Starting from July 2022 the activation process for non-SELECT accounts has changed so that it requires to register machines, on which the licenses will be used.
Please refer to the following articles for more information:
Announcement: non-SELECT Announcement and FAQs
Process: Machine Registration for non-SELECT accounts
Please note the new process is not a change in policy, it is a change in enforcement.
Most version 8.9 and 8.11 applications activate using a SELECTserver style license.
Online activation of the software is achieved by entering a server name and site activation key into the product. The Server Name and Site activation key are entered into the "Product Activation Wizard" or into the “License Management Tool”.
For NON-SELECT users, the server name will always be ProductActivation.bentley.com.
Offline activation is achieved by having an Administrator supply the user with a checked out license in the form of an ".XML" file, and the user preceding to import the license file onto the License Management Tool on the workstation.
In any case, activation checks out the license from the product activation server and on the machine, and by default, the checkout is for one year, which is the maximum term.
Non-SELECT licensing is version and machine specific. You may not freely switch between different versions of the same application.
If you are trying to activate a Non-SELECT license, for the first time, and get an error message saying that "The version number does not match" then do the following.
1. Make sure all versions of the Bentley Application has been uninstalled.
2. In the PDF document you received containing your Download Links for the Bentley Software and the Licenses > Download the Bentley Application from the provided link.
3. Install the Bentley Application.
4. Activate the Bentley Application from Licensetool.exe (Make sure that you run Licensetool as Administrator).
Obtaining your Bentley Software License
Please follow the Product Activation Wizard Instructions below. You may be put straight into the “Product Activation Wizard,” If the Product Activation Wizard does not prompt upon launching the application, you can activate using the License Mangement Tool.
Once selected, click Next> in the bottom right corner.
Fill in the Site Activation Key in the Site Activation Key box. Due to the length of the site activation key, it is recommended that each user copy and paste the information directly into the license management tool. Also, be sure there are no extra spaces before or after the server name and site activation key as this can prevent a proper activation.
Depending on what version of software in being installed, the country where the product will be in use may have to be selected.
User's must be supplied a checked out license in the form of an ".XML" file by an administrator. This also works for users unaffiliated with your account.
Administrator Check Out Instructions -
How to check out licenses from Entitlement Management
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0018789
How to Transfer a Checked Out License from one Machine to Another
To transfer a non-Select nodelocked license from one machine to another:
1) Check the license back into Entitlement Management (this releases the license) -
This is covered under Step 3 of the following WIKI -
2) Activate the software as a non-Select user on the new machine following above instructions.
Product Activation TechNotes and FAQs
SELECTserver TechNotes and FAQs
How to check out licenses in the Entitlement Management
Activating as a non-Select User via SES
Deutsch - Français - Nederlands
