CONNECTION Client Will Not Install
Product(s):CONNECTION Client
Version(s):10.00.08.18
Environment:N\A
Area:Installation
Subarea:N\A
Problem Description
When I click on the CONNECTION Client executable to install nothing happens. This occurs when your Windows username has a special character (@#$%)  in the name like Abc#123. If you're doing an application update from the CONNECTION Client it fails if your Windows username has a space in the name (John Smith).
Steps to Resolve
  1. Open command prompt and type
  2. mkdir C:\temp\
  3. Set TEMP=C:\temp\
  4. Set TMP=C:\temp\
  5. Then run the CONNECTION Client executable from the command prompt.
Cloud and Web Services Wiki
Other language sources
Deutsch
