Product(s): | Power Rail Track |
Version(s): | 08.11.09+ |
Area: | Geometry |
Question:
How to create a turnout library for specific project as the options available to create new turnout library is disabled ?
Answer:
First save turnout XML file in a folder where you have read/write access then you would have to open Turnout Library dialog box, go to File > Open your Turnout XML file
By default it is readonly in: C:\ProgramData\Bentley\Civil\InRoads\8.11.9\en\metric <turnoutlibrary>.xml
