| Version(s): | 10.10.01.03+ |
| Area: | Drawing Production |
| Original Author: | Holly Herring, Bentley Technical Support Group |
The levels are grayed out in my Drawing and Sheet model for the referenced files. I get a message "Level State is Controlled by Saved View Level is ON in Active View" when I hover over a level. How can I change this to be able to control this within the Drawing or Sheet model?
This setting is being pulled from the dgnlib. The change can be done within the dgn or the dgnlib. It is recommended to apply it to the dgnlib if you want this setting across all drawing/sheet models.
