| Version(s): | 10.08.01.33+ |
| Area: | Drawing Production |
| Original Author: | Holly Herring, Bentley Technical Support Group |
Question:
How do I automatically create cross sections at Event Points?
Answer:
- Open the dgn that contains the Baseline alignment used for the cross section creation.
- Run the command OpenRoads Modeling > Geometry > Common Tools > Event Point List. Add the Stations to this list that you want included as cross sections
- Open the dgn that will contain the cross section sheets.
- Select the Named Boundary Civil Cross Section command.
- Select the alignment in the View Window.
- Select the Event Point List in the pull down to use. If you check "Include Event Points Only" it will only create Named Boundaries for the stations listed in the list.
