New Administrator's Guide
User Management Landing Page
As Administrator, you are the central contact for your organization's users, for User Management, Entitlement Management (licensing), and Subscription Analytics.
Consider having a co-administrator to be able to action things in your absence. This can be done in User Management by assigning a co-administrator role to an existing user. For details, see: Managing Roles.
For Virtuoso Subscriptions – Practitioner Licenses
If your organization is using a Virtuoso subscription, software access is managed through Practitioner Licenses.
These are named-user licenses that must be assigned by an Administrator or Co‑Administrator in Bentley Entitlement Management before users can access the software.
For step-by-step guidance on registering users, assigning Practitioner Licenses, and downloading software, see:  Getting Started with Practitioner Licenses
Understanding Bentley's licensing Philosophy
Bentley's licensing philosophy, Trust Licensing, is centered on ensuring that users are never deprived of access to their mission-critical software when it is needed. This approach means that licensing never gets in the way of users getting productive work done. This licensing philosophy was built upon the feedback from Bentley's accounts, who indicated their number one priority was ensuring that software access was never a barrier to meeting their deadlines.
Bentley's Licensing Model, Subscription Entitlement Service licensing
Trust licensing remains the core philosophy implemented by CONNECT Licensing, but it provides many additional capabilities that will allow organization administrators to better manage their license usage. Many of the capabilities included in CONNECT Licensing are based on direct feedback from our users.  Some of these capabilities include:
CONNECT Licensing will provide a near-real-time licensing experience that will provide enhanced administrative management tools while not sacrificing the flexibility and reliability of the Bentley Trust Licensing philosophy.
CONNECT Licensing integrates a new CONNECT License Client with Bentley's Identity Management System (IMS).  This means that license keys will no longer be used to activate Bentley software, and they will be replaced by a user's log-in (IMS) credentials.  If a user leaves the company, they can be removed from your account and will no longer have access to your licenses.
Using log-in credentials to license your Bentley software also provides the ability to deliver near-real-time reporting of usage,e including insight into who is currently using licenses.  Alerts can be displayed at the time a license is used to notify end users when they may exceed your pool of perpetual licenses, es and notifications can be sent to account administrators if a user is about to use a Term License.
To realize the benefits of CONNECT Licensing, an internet connection is required.  Offline usage of Bentley software is still supported in the CONNECT License Client; however, if offline usage occurs, users will not be able to take advantage of CONNECT Licensing license management capabilities.  Having a near-real-time connection is a prerequisite to providing users with tools to manage usage.
For more information, see:
Understanding the Subscription Entitlement Service (SES) Workflow
SES Activation
Subscription Services Portal
What is User Management?
Bentley, like most software vendors, is moving towards a user-based, cloud-based, subscription-based licensing.  User Management is pivotal to ensuring that users have access to the correct licenses. User Management includes -
You should strive to keep your information under User Management current  - This includes proactively adding new users as people join your organization, and removing users as they leave your organization.
NOTE:
Users can only be associated with a single account, and they use their login to access the licensing associated with their account.
User Management 2.0
Managing Fulfillment Contacts
What is Entitlement Management?
Entitlements are just another way of saying licenses. As a site administrator, you control who has access to entitlements through the entitlement management portal. Capabilities include setting up license alerting, enabling or disabling access to a specific license.s
Currently, ly Bentley only supports two license models -
Subscription Entitlement Service licensing (interchangeably called "CONECT Licensing")
Subscription Entitlement Service licensing is Bentley's current license model. Subscription entitlement service-based licensing functions by logging into a desktop client, CONNECTION Client, and then the Bentley licensing tool proceeds to fetch a policy from Bentley so that it knows what applications the end user is entitled to run.
Restricting License Usage
Since Subscription Entitlement Service licensing is a real-time-based licensing model, it is possible to restrict usage by individual user or entitlement group (which is a group of users defined under User Management).
It is also possible to set up license alerts to alert users when they are about to exceed an administrator-defined usage threshold.
SELECT server-based licensing
SELECT server-based licensing is the older of the two licensing models; no new products have been released that utilize SELECT server-based licensing for several years.SELECT server-based licensing has been deprecated and monetized.
Select server-based licensing is not a real time licensing model; The actual application doesn't ping a server in real time for permission to run, rather usage has recorded locally and is transmitted previously accrued usage is transmitted on the following day. Because of this, it is not possible to restrict usage of SELECT server-based applications (and basically anyone having the server name and site activation key has access to an accounts license.
For select server-based licensing, the main interface is the license management tool, into which the server name and site activation key are interred proxy settings can be answered.
Select server-based licensing functions by giving the application a server name inside an activation key with which to retrieve a license.
What is Subscription Analytics?
When you have questions about your account's usage, this is where you would go to find the answers.
Subscription Analytics allows you to monitor the versions of the applications your users use and the frequency with which those users access your account's licenses.
Summary of reports
Earned Value Discount
Bentley’s Earned Value Discount (EVD) offers you the opportunity to save with three discount components: volume, version, and the Enterprise License Subscription (ELS).  The Earned Value Discount report allows you to check your EVD status and see how to maximize your discount.
Usage Details
Displays the machine, Windows user, and IMS user together down to the 10-minute interval in which an application was used. All usage for the last 90 days is included. The times are in UTC.
Visa Consumption
Counts the quantity of Passports and Visas consumed per quarter. Only production usage beginning May 1st,2019, is included.
CONNECTION Client inventory
Inventories your machines based on their CONNECTION Client usage. Only production usage for the past sixty days is included.
E365 Usage
Shows your application usage and spend specific to the E365 billing program. This report defaults to the current quarter. All usage beginning with 2019 Q4 is included.
Alert history
Shows a history of all in-product SES licensing alerts, and the ensuing user action is configured in entitlement management
Activation Key Audit
View which activation key each machine is using to activate the Bentley product.
SELECT server usage fee
This report shows how much accounts will be charged per quarter for not using the current software.
Cloud Service Usage
How long each cloud service was used on Beachday Realtime Usage
The quantity of Connected users currently using Connect Edition applications.
Activation Key Mappings
Allows you to map your SELECTserver Custom Activation Groups to new Allocation or Entitlement Groups.
Data Export
Export the raw data underlying most of the Subscription Analytics reports for ad hoc analysis. You may export as far back as two years (maximum 3-month chunks), and all usage is included.
Entitlement Exceptions
The application entitlement exceptions are configured in Entitlement Management for countries, entitlement groups, and users. Only applications with at least one user or group exception will be listed here.
Other Language Sources
Deutsch
Polski
