| Version(s): | 10.10.00+ |
| Area: | General |
After upgrading a file to the current release, the Default 2D model displays Dynamic Cross Section grid and data, and all other model views display cross section grids and incorrect views of the model.
Some older files may display this behavior after upgrading.
The video below demonstrates this procedure:
