| Version(s): | 10.00.00.120+ |
| Area: | Drawing Production |
| Original Author: | Holly Herring, Bentley Technical Support Group |
Question:
Where do I define my feature definition libraries in my workspace?
Answer:
Feature definition libraries are defined in the variable, CIVIL_CONTENTMANAGEMENTDGNLIBLIST. To add a feature definition DGNLIB to this variable:
- Go to File > Settings > Configuration > Configuration Variables in the MicroStation menu.
- Locate the variable, CIVIL_CONTENTMANAGEMENTDGNLIBLIST, in the list.
- Select Edit.
- Change the Edit Mode to "Append" and add the file path to the DGNLIB you wish to add.
- You can also use a wild card to capture all DGNLIBs in the specified folder.
- Select OK.
- Save the configuration file.
___
Other language sources
German
