| Product(s): | Bentley MXRoad | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This functionality will help all in Downloading the MX Software from Bentley Select Server.
Steps to download the software Bentley MX V8i from Select Server:
2. Then click on the Downloads. After clicking on the download page will shown as below:
3. Then Click on the Software Downloads/My select CD (on the left side). Then it will ask you to login with the username and password as shown below:
4. After enter the valid User name and password the window will shown as below:
5. Then select the Product Bentley MX (as shown above in figure) and click on search and then go roll the page down shown in snapshot below.
Note: Show Dependencies required supporting files should be checked on.
Then check for example on the Bentley MX V8i (version 08.11.07.536) and also on dependencies (just below) as shown below:
6. Then down the page and click on continue as shown below:
7. Then page will show as below:
8. Then click on Continue and then in next page roll down and click on accept as shown below
9. After clicking on accept page will show as below
10. Then click on Download all the files.
11. After download, first install Prerequisites for Bentley Desktop Applications (second one, Bentley Desktop Applications) and
12. Then Microstation V8i and then MX V8i.
___
