Creating a new Service Request (Technical Support)
Access Service Request Manager as described here.
Below describes how to log a new technical, product-related Service Request using Technical Support tile; other categories/forms follow the same design, sharing many fields or options. Please note that unique form is presented to users without maintenance contract (NON-SELECT) or users with valid Managed Services contract.
Technical Support
Please fill out the form. There is guidance below on how to complete the entries.
FieldWhat to Enter
Severe Production ImpactCheck this box if your issue directly impacts production environment, business, project or deadline
 • This will automatically set the Issue Category as well as Priority
Issue CategoryCategorize type of the issue you are reporting (Incident, Request or Enhancement)
 • Product Enhancements Requests are prioritized by Product Management - Priority and Impact are not available.
 • Other Priority restrictions apply based on categorization
Phone NumberPlease provide your direct phone number where you can be reached if needed (optional)
PriorityMeasure how urgent the issue is
 • Available options are driven by Issue Category
ImpactPick the value from the list that reflects how many sites or users are affected
ProductFree form search field that will populate product name as you type
VersionSelect from the list of versions applicable to the selected Product. If your version is not in the list choose the nearest and enter the actual version in the details
Product AreaChoose the most appropriate keyword from the list
Product LanguageSelect the language you use in the Product
SubjectEnter a short description of the issue (max 40 characters)
User Tracking NumberOptional field that can be used to map Bentley’s Service Request number to your own Support systems
Details
Please provide as detailed description of the issue as possible, including where appropriate:
 • steps taken
 • full error details
 • whether the same happens for other users
 • how many times the issue has occurred - e.g. does it happen every time or is it intermittent?
Upload File
If suitable, attach a test case and/or screenshots that demonstrate the issue. Compressing, especially if multiple files is strongly recommended.
Click on Submit to Support button
Next page will confirm successful creation a of a new Service Request, please note the SR number (email address will also receive confirmation email)
confirmation page
Other Language Sources
Polski
Deutsch
Italiano
