Access Service Request Manager as described here.
Below describes how to log a new licensing and user administration related Service Request using Licensing and User Administration tile; other categories/forms follow the same design, sharing many fields or options. Please note that unique form is presented to users without maintenance contract (NON-SELECT) or users with valid Managed Services contract.
Please fill out the form. There is guidance below on how to complete the entries.
Field |
What to Enter |
Severe Production Impact |
Check this box if your issue directly impacts production environment, business, project or deadline |
Issue Category |
Categorize type of the issue you are reporting (Incident or Request) |
Phone Number |
Please provide your direct phone number where you can be reached if needed (optional but strongly recommended) |
Priority |
Measure how urgent the issue is |
Impact |
Pick the value from the list that reflects how many sites or users are affected |
Problem Area |
Select from the list of various areas |
Subject |
Enter a short description of the issue, if not auto populated (max 40 characters) |
User Tracking Number |
Optional field that can be used to map Bentley’s Service Request number to your own Support systems |
Details |
Please provide as detailed description of the issue as possible, including where appropriate: |
Upload File |
If suitable, attach a test case and/or screenshots that demonstrate the issue. Compressing, especially if multiple files is strongly recommended. |
Click on Submit to Support button
Next page will confirm successful creation a of a new Service Request, please note the SR number (email address will also receive confirmation email)
