Applications under User Management portal are supported on the latest versions of these browsers.
Note: Internet Explorer and Edge "old version" are not supported. Continued use of these browsers may result in errors or unexpected results.
Go here to learn more on Microsoft's support for these browsers.
Note: Other Chromium-based browsers will likely work fine, but are untested.
