STAAD.Pro
V22 CONNECT Edition Update 6 (Build 22.06.00.138)
V22 CONNECT Edition Update 7 (Build 22.07.00.160)
V22 CONNECT Edition Update 8 (Build 22.08.00.175)
- Only data files local to the Citrix server are supported
STAAD Foundation Advanced
V22 CONNECT Edition Update 5 (Build 09.05.00.62)
V22 CONNECT Edition Update 6 (Build 09.06.00.62)
V22 CONNECT Edition Update 6 (Build 09.06.01.74)
- The link for “Examples” on the Home Page is non-responsive. However, the Examples folder can be browsed with the help of “Open File” option on the Home page
STAAD Advanced Concrete Design RCDC
V10 CONNECT Edition (Build 10.00.00.278)
V11 CONNECT Edition (Build 11.00.00.143)
V11 CONNECT Edition (Build 11.01.00.180)
- Reading of .mdb files not supported
- Reading of RAM files not supported
