How can I process multiple corridors or all corridors in one file?
Answer:
  1. In the Project Explorer, navigate to the OpenRoads Model tab,
  2. then right-click on the filename and select "Process All Objects" from the context menu.
Keyin = GEOMETRY PROCESSALLOBJECTS
