Product Consolidations
Product Specific Licensing Landing Page
Occasionally Bentley will bring out new products which are consolidations of the functionality of existing applications. The older applications that are being replaced are then known as legacy applications.
 When this happens, typically contracts go thru a migration process -
Licensing of Legacy Applications
Sometimes (but not always), legacy applications are added as a "child product" of the new application, essentially giving the new licensing the ability to run the older applications it replaces.
Analytics Data Export
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0018794
List of Product Consolidations
AutoPLANT Modeler Consolidation
AutoPLANT Modeler  is an application that replaces the capabilities of the following applications in a single offering:
Bentley Infrastructure Cloud Entitlement Consolidation
New packaging for Bentley Infrastructure Cloud, including ProjectWise and SYNCHRO went live on December 1, 2025.
For ProjectWise Manage and SYNCHRO Field users, your entitlement will now be shown as Bentley
Infrastructure Cloud Connect.
For ProjectWise Engineer and Validate and SYNCHRO Control Users, your entitlement will now be shown
as Bentley Infrastructure Cloud ProjectWise.
To learn more about these changes, refer to the resource Center -
Bentley Infrastucture Cloud Resource Center
https://bentleysystems.service-now.com/community?id=bentley_infrastructure_cloud_landing
iTwin Capture Modeler Consolidation
Bentley streamlined iTwin Capture Modeler offering. This will make it easier for Users to access the capabilities they need, reduce product complexity, and improve performance across their reality modeling workflows.
Several legacy iTwin Capture Modeler on-prem products will transition to a new, simplified portfolio designed to support both on-prem and cloud processing.
LEGION Consolidation
The two products LEGION Model Builder and LEGION Simulator have been combined into one single LEGION license/subscription.
LEGION now licenses the items below:
OpenFlows Product Bundling
Bentley bundled products within our OpenFlows software solution, simplifying the array of separately available licenses.  
OpenFlows StormCAD, OpenFlows CivilStorm, and OpenFlows PondPack were bundled into OpenFlows Storm
OpenFlows StormCAD, CivilStorm, and PondPack License Consolidation
OpenFlows FlowMaster and OpenFlows CulvertMaster were bundled into  OpenFlows Hydraulic Toolset
OpenFlows FlowMaster and CulvertMaster License Consolidation
OpenFlows SewerCAD and OpenFlows SewerGEMS were bundled into  OpenFlows Sewer
OpenFlows SewerCAD and SewerGEMS License Consolidation
OpenFlows WaterCAD, OpenFlows WaterGEMS, and OpenFlows HAMMER were bundled into OpenFlows Water
OpenFlows WaterCAD, WaterGEMS, and HAMMER Consolidation
OpenFlows Storm, OpenFlows Sewer, and OpenFlows Water and available in multiple levels; Essentials, Standard, Advanced, and Ultimate levels
If you have restricted access to entitlements via default access setting or entitlement group, or have configured license alerting, you will have to restore these settings based on new product names. See the below articles for details -
OpenFlows Product Licensing and Feature Levels (New for 2024)
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0037902
Simplifications to Bentley's Water Software Licenses
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0037363
OpenPaths Consolidation
The CUBE, EMME, DYNAMEQ and AGENT products are being retired and consolidated into a new product called OpenPaths.
OpenPaths has two tiers, Advanced and Ultimate.
OpenRail Designer Consolidation
OpenRail Designer  is an application that replaces the capabilities of the following applications in a single offering:
OpenRoads Designer Consolidation
OpenRoads Designer  is an application that replaces the capabilities of the following applications in a single offering:
OpenSite Designer Consolidation
OpenSite Designer is a new application that replaces the capabilities of the following applications in a single offering:
OpenRoads Designer vs OpenSite Designer Comparison
Here's a chart to make it easier to look up what each legacy application was replaced by, as these two consolidated products share a lot of similar legacy applications.
Product
Replaced by?
Bentley GEOPAK Civil Engineering Suite
OpenRoads Designer
GEOPAK Site
OpenSite Designer
GEOPAK Survey
OpenSite Designer
InRoads
OpenRoads Designer
InRoads Site
OpenSite Designer
InRoads Site Suite
OpenSite Designer
InRoads Storm and Sanitary
OpenSite Designer
InRoads Suite
OpenRoads Designer
InRoads Survey
OpenSite Designer
Bentley GeoMacao
OpenRoads Designer
MXGRONDWERK
OpenSite Designer
MXGRONDWERK Addin
OpenSite Designer
Bentley MXROAD
OpenRoads Designer
Bentley MXROAD Suite
OpenRoads Designer
MXSITE
OpenSite Designer
MXSUBDIV
OpenSite Designer
Bentley PowerCivil
OpenSite Designer
PowerCivil for Countries
OpenRoads Designer
Power InRoads
OpenRoads Designer
Power GEOPAK
OpenRoads Designer
PowerSurvey
OpenSite Designer
Subsurface Utilities Design and Analysis
OpenSite Designer
Bentley topoGRAPH
OpenSite Designer
Bentley topoGRAPH Projects
OpenSite Designer
Orbit desktop product consolidation / renaming
Orbit 3DM desktop products have been consolidated. The remaining product is also renamed. The changes are detailed below.
Renamed Materials
Orbit 3DM Content Manager was renamed to  iTwin Manage & Extract Perpetual License
Retired Materials
The following products have all been retired. The functionality of these is all included in the core functionality of iTwin Capture Manage & Extract.
Orbit 3DM Feature Extraction Basic
Orbit 3DM Feature Extraction Standard
Orbit 3DM Feature Extraction Pro
3DM Feature Extraction Standard Server
PLAXIS License Consolidation
When moving from Plaxis v20 to Plaxis v21, the  offerings were reduced to just 3 product tiers -
PLAXIS 2D / PLAXIS 3D
PLAXIS 2D / 3D Advanced
PLAXIS 2D / 3D Ultimate
PLAXIS V20 License
New license in
PLAXIS CE V21
PLAXIS 2D Basic without additional modules
PLAXIS 2D Advanced
PLAXIS 2D Basic with PlaxFlow
PLAXIS 2D Ultimate
PLAXIS 2D Basic with Dynamics
PLAXIS 2D Ultimate
PLAXIS 2D Basic with Thermal
PLAXIS 2D Ultimate
PLAXIS 2D Basic with PlaxFlow and Dynamics
PLAXIS 2D Ultimate
PLAXIS 2D Suite (Dynamics+PlaxFlow+Thermal)
PLAXIS 2D Ultimate
PLAXIS 3D Basic without additional modules
PLAXIS 3D Advanced
PLAXIS 3D Basic with PlaxFlow
PLAXIS 3D Ultimate
PLAXIS 3D Basic with Dynamics
PLAXIS 3D Ultimate
PLAXIS 3D Basic with PlaxFlow and Dynamics
PLAXIS 3D Ultimate
PLAXIS 3D Suite (Dynamics+PlaxFlow)
PLAXIS 3D Ultimate
See also:
Starting PLAXIS
PLAXIS CONNECT Edition V21 licensing changes
RAM Structural System Consolidation
RAM Structural System will no longer be sold as five individually priced modules. Instead it is now sold
and fulfilled under the name RAM Structural System, a single license, which replaces the following individual licenses -
Other language Sources
Deutsch
Polski
