| Version(s): | 10.10+ |
| Area: | Drawing Production |
Question:
I'm looking for the key-in command to open the Named Boundaries Manager for OpenRoads. The normal key-in: "dialog named boundaries toggle" only opens the MicroStation Named Boundaries Manager:
and not the OpenRoads version (see below):
Answer:
Use the following command to open civil’s named boundaries dialog: “doccenter open namedboundariesmanager”.
___
TIP: The easiest way to find key-in required is to record a macro. “Drawing>Utilities>Macros>Record” and then edit it to see keyin. See sample video:
