Video: Combining Multiple Geometry Builder XML files into one XML
Product(s):OpenRoads Designer
Version(s):10.09.00.91+
Area: Geometry
This video will demonstrate the process for using an XML Editor to combine multiple XML files generated from the OpenRoads Designer Geometry Builder tool into a singular XML. This way a single XML can be utilized to view all the information created by the Geometry Builder Tool.
https://youtu.be/XEsPpsh5-8E
