| Product(s): | OpenRoads Designer CONNECT Edition |
| Version(s): | 10.00.00.120 |
| Area: | Licensing |
For a full list of OpenRoads Designer CONNECT Edition FAQs, please download the Fact Sheet from the following location: communities.bentley.com/.../download
Question 1: What license is required to run OpenRoads Designer CONNECT Edition?
Answer 1: A license for the product "OpenRoads Designer" (Product ID 2515) is required.
Question 2: What other products can I run using an OpenRoads Designer license?
Answer 2: The list below shows products that can be run using an OpenRoads Designer commercial license. Please note that OpenRoads Designer "Practitioner" licenses only cover the use of OpenRoads Designer.
| • GEOPAK Civil Engineering Suite | • PowerCivil Baltics | • PowerCivil Latin America |
| • Power GEOPAK | • PowerCivil Benelux | • PowerCivil Middle East |
| • Bentley GeoMacao | • PowerCivil Brazil | • PowerCivil Norway |
| • InRoads | • PowerCivil China | • PowerCivil Poland |
• InRoads Suite | • PowerCivil Czech Rep | • PowerCivil Portugal |
| • Power InRoads | • PowerCivil DACH | • PowerCivil Russia |
| • MXROAD | • PowerCivil Denmark | • PowerCivil South Africa |
• MXROAD Suite | • PowerCivil Finland | • PowerCivil Spain |
| • PowerCivil Americas | • PowerCivil France | • PowerCivil Sweden |
| • PowerCivil Italy | • PowerCivil Turkey | |
| • PowerCivil Japan | • PowerCivil UK & Ireland |
Question 3: Is a separate license required to run the SUE/SUDA tools, the gINT Civil Tools, or the Reality Modeling tools that are included in OpenRoads Designer?
Answer 3: No, all the tools delivered with OpenRoads Designer are included in the OpenRoads Designer license. This includes the SUE/SUDA tools (up to 100 nodes), the gINT Civil Tools, and the Reality Modeling tools.
Question 4: Does having a license of OpenRoads Designer allow me to use a license of MicroStation for free?
Answer 4: No. OpenRoads Designer is built on the MicroStation platform, and allows the use of MicroStation functionality within ORD. However, this does not mean that a user has a separate/additional MicroStation license. A user can open ORD and use the MicroStation commands within ORD. Starting a pure MicroStation session will require a standalone MicroStation license.
Question 5: Are we able to install and run the stand-alone version of OpenSite Designer without being charged extra?
Answer 5: No, OpenSite Designer stand-alone is not included in an OpenRoads Designer license. See OpenSite FAQ.
Note: OpenRoad Designer needs to be explicitly on contract in order to access the legacy applications noted above. SELECT Open Access alone does not entitle these licenses.
