| Product(s): | SELECTserver | ||
| Version(s): | N\A | ||
| Area: | N\A | ||
| Subarea: |
N\A | ||
| Original Author: |
Jutta Eisenhauer |
When activation of products from version XM (08.09.xx.yy) is not possible, the user must create a log file for further troubleshooting by Support
Creating an extended log file on the affected client computer:
Open License Manager, see:
http://communities.bentley.com/products/licensing/w/licensing__wiki/21055.opening-license-management-tool
In newer installations, in the License Manager located under Tools > Options, the tab Error Logging can be found.
Enable all Options under Log Levels and specify an output file by clicking on the "Change"-button.
If the "Error Logging"-tab is not (yet) available, due to an old(er) installation, the following two envrionment variables in the Operating System (in the Control Panel under System, the "Advanced"-tab, click the "Environment Variables"-button) should be set:
MS_LMDEBUGLOGLEVEL=ALL
and
MS_LMDEBUGLOGFILE=C:\AppLICBEBUG.LOG
Now check the Activation Key in the License Manager, send the Usage Logs (in the License Manager under Tools > Send Logs Now, or direcly via hotkey F9) and close the License Manager again.
Then try to launch the product which could not be activated.
Please repeat these steps.
Now e-mail the created file in ZIP-format through the Case to Support
Note:
Creating a log file can lead to significant performance issues when starting a product.
Therefore, the setting should be reset after successful creation.
Program starts up slowly after the creation of a log file
http://communities.bentley.com/products/licensing/f/275813/t/73843
Deutsch
