Subscription Analytics Landing Page
Purpose
Bentley’s Earned Value Discount (EVD) offers you the opportunity to save with the discount components of volume and version. This report allows you to check your EVD status and see how it was calculated.
Roles
Users with at least one of the following roles are able to access the report:
Access
EVD report is not accessible to e365 organizations.
It will open on the EVD report Dashboard, which allows you to gain insight to your savings and help maximize your Earned Value Discount.
Use the Help page to learn about the Earned Value Discount, its components, and report navigation.
Other Language Sources
