| Product(s): | OpenRoads ConceptStation | |
| Version(s): | 10.00.05.99 | |
| Area: | ConceptStation | |
| Original Author: | Amita Shinde |
This video demonstrates the steps to attach a 3sm file in OpenRoads ConceptStation. The ground extraction tool is used to define a region on which the ground will be detected and everything within this region will be flattened to create the terrain. This tool is like a cleanup tool.
