| Product(s): | CONNECTION Client |
| Version(s): | 11.00.02.xx and newer |
| Area: | Federation |
CONNECTION Client displays a connectivity error when attempting to access an internal server during federated sign-in.
If a proxy server is in use and fails to recognize internal addresses, configure the WebView2 component utilized by CONNECTION Client with a proxy bypass using the following steps:
Other Language Sources
