Deployed SELECTserver Technical Requirements [TN]
SELECTserver Licensing Landing Page
  Product(s): SELECTserver
  Version(s): 08.11.07.111 - 09.01.00.31
  Environment:
N/A
  Area: Installation / Configuration
  Subarea: N/A
Supported Operating Systems - SELECTserver
Version 09.01.00.26 and later
Version 09.00.00.113 and earlier
NOTE: Installing SELECTserver on a Domain Controller is not supported.
Small Business Servers (SBS) contain Domain Controllers and are not supported
Supported Operating Systems - SELECTserver Gateway Service
NOTE: All Versions of Windows 2003 Server will also require the installation of Windows Imaging
             Components which can be downloaded from here
Supported Encryption
If using HTTPS to communicate with our hosted SELECTserver (i.e. selectserver.bentley.com) ensure .NET Framework is configured to permit use of TLS 1.2. The following commands derived from a Microsoft technical article can be executed from an Administrator Command Prompt or Windows PowerShell console to enable it:
reg add HKLM\Software\Microsoft\.NETFramework\v4.0.30319 /v SchUseStrongCrypto /t REG_DWORD /d 1 /f
reg add HKLM\Software\Wow6432Node\Microsoft\.NETFramework\v4.0.30319 /v SchUseStrongCrypto /t REG_DWORD /d 1 /f
reg add HKLM\Software\Microsoft\.NETFramework\v2.0.50727 /v SystemDefaultTlsVersions /t REG_DWORD /d 1 /f
reg add HKLM\Software\Microsoft\.NETFramework\v4.0.30319 /v SystemDefaultTlsVersions /t REG_DWORD /d 1 /f
reg add HKLM\Software\Wow6432Node\Microsoft\.NETFramework\v2.0.50727 /v SystemDefaultTlsVersions /t REG_DWORD /d 1 /f
reg add HKLM\Software\Wow6432Node\Microsoft\.NETFramework\v4.0.30319 /v SystemDefaultTlsVersions /t REG_DWORD /d 1 /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2\Client" /v DisabledByDefault /t REG_DWORD /d 0 /f
Supported Browsers
Supported SQL Server Databases
Note: SQL SERVER 2000 and MSDE are no longer supported.
        *SQL SERVER 2019 is not supported on any version of SELECTserver.
Software Prerequisites - SELECTserver requires:
Software Prerequisites - SELECTserver Gateway requires:
Version 09.01.00.xx
Version 09.00.00.xxx
Note:  The current SELECTserver Gateway installer does "NOT" put these prerequisites in place. Please ensure their presence before installation.
Version 08.11.xx.xxx
Product TechNotes and FAQs
Licensing TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to the "Comments" area below. THANK YOU!
Other Language Sources
Deutsch
