| Product(s): | OpenRoads ConceptStation |
| Version(s): | 10.00.00.108+ |
| Area: | ConceptStation |
Question:
Can you provide a list of sites and IP addresses that OpenRoads ConceptStation needs to access?
Answer:
https://connect-contextservices.bentley.com/ (for GeoCoordination Services)
For Update 7 or newer
https://connect-geoportalmapservice.bentley.com/ (for Map Control)
For Update 6 or older
https://api.mapbox.com (for Map control)
https://a.tiles.mapbox.com (for Map control)
https://b.tiles.mapbox.com (for Map control)
ftp://rockyftp.cr.usgs.gov (for USGS files)
https://prd-tnm.s3.amazonaws.com (for USGS files)
https://dds.cr.usgs.gov (for USGS files)
https://s3-us-west-2.amazonaws.com (for USGS files)
https://www.openstreetmap.org/
http://overpass-api.de (for OpenStreetMap)
For Bing Maps:
https://dev.virtualearth.net
http://dev.virtualearth.net
http://ecn.t*.tiles.virtualearth.net
Also, please see this article for the connection requirements for CONNECT: http://communities.bentley.com/products/licensing/w/licensing__wiki/6857.connecting-to-the-bentley-servers-through-firewalls-and-proxy-servers-faq
