Question: Why am I getting this error message when I try to import static imagery into my .dgndb?
Answer: ConceptStation pulls data from multiple sources, so you may need to check with IT if traffic to the server is blocked. Click here to view an article with a list of sites that ConceptStation uses to import data.
If nothing is blocked and you are still getting this message, then you may be trying to pull static imagery in a location that no longer provides it for free. A lot of static imagery is now a costed option (even in areas where it used to be free). We recommend using Bing maps.
