Subscription Analytics Landing Page
Subscription Analytics is the portal used to view Bentley application usage reports. This usage data is sent to Bentley and processed at least every two days. Please check the Bentley Privacy Statement for further information. Refer to the following instructions to access the Subscription Analytics reports.
The Usage and Analytics Reports allow you to see how Bentley applications are used across your organization and track progress on select Bentley initiatives.
Please reference the pages in the Bentley Cloud Services Wiki for detailed information about each report and how to use them.
Other Language Sources
