Video: Using the "WHERE" Clause when importing data through ModelBuilder
Product(s): OpenSite, OpenRoads, OpenRail Designer Connect Edition
Version(s): 10.10+
Area:  Drainage and Utilities
This video will demonstrates how to use the "WHERE" Clause in the ModelBuilder tool in the Drainage and Utilities workflow inside OpenRoads, OpenSite, or OpenRail Designer.
