Accessing Enterprise Role Management
NOTE: In order to access the Subscription Services Portal > Roles and Permissions you must have the Administrator or Co-Administrator role.
1. Go to https://connect.bentley.com and Sign In
2. Click on your company name at the top to access the  Subscription Services Portal
3. Click the Roles and Permissions tile
4. Select Define Roles
5. The Enterprise Role Management page will launch
Other Language Sources:
EspaƱol
Deutsch
