Delivered Roles and Permissions
Question
What are the default Enterprise Roles delivered to every organization? Which services have settings enabled for each role?
The delivered Enterprise roles are Project Administrator and Team Member.
The Project Administrator role should be assigned to any team member of the project that needs administrative control of the project. The Project Administrator can manage project activities like editing or change project properties, adding and removing team members of the project, and much more.
The Team Member role should be assigned to anyone that is working on the project that does not need administrator access.
The basic settings enabled for each role are as follows:
ServicesProject AdministratorTeam Member
Project ActivitiesX
AdministrationX
ProjectWise Work Rules ServiceX
Machine Learning Admin
ShareXX
iModelHubX
ProjectWise ContextShareX
PS Federated ConnectionX
Expert AdvisorX
Scenario ServicesX
Project Insights ServiceXX
ProjectWise FormsXX
Construction ServicesX
Components CenterX
Product Settings ServiceX
iModelDataManagerX
Validation ServiceX
Quantity Take-Off Configuration ServiceX
IModel Schema Management ServiceX
PdfGeoIndexingServiceX
Extension Service
SYNCHRO
4D Scheduling Permissions
ProjectWise Deliverables ManagementXX
Document Registry Service
SYNCHRO Bid
Design Insights
Design Validation
Subscription Services
Engineering Data Manager
PlantSight Portal
Machine Learning API
Insights and Reporting
SYNCHRO Cost
Other Language Sources
Deutsch
