Permission Descriptions
Subscription Services Landing Page
Permission Category Category Description Service/Application Permission Permission Description
Project Activities Manage Project Settings for created projects Project/iTwin Provision Project from a Template Provision a project from a template
Administration Manage Administrative Setting / Access Control
Project/iTwin Edit Project Properties from Portal Edit Project Properties from Portal
Invite & Configure Team Participants Invite & Configure Team Participants
Create / Modify Team Roles & Permissions Create / Modify Team Roles & Permissions
Remove Team Participants
Access Team Member and Role Management Access Team Member and Role Management
Manage Project Access and Billing Settings Manage Project Access and Billing Settings
Manage External Organizations Manage External Organizations
Create New iTwin Create New iTwin
Share Manage Access to Cloud Document Storage ProjectWise Share Read Share Read Permission
Read / Write Share Read & Write Permission
Read / Write / Delete Share Read, Write, and Delete Permission
Configure Folder Access Configure Folder Access
iModelHub  Manage Access to iModels iModels View View and iModel in a web browser
View / Read Read an iModel (download)
View / Read / Write Modify and iModel
View / Read / Write / Manage Create an iModel & Configure
View / Read / Write / Manage / Delete Delete an iModel
ProjectWise ContextShare Manage Access to Reality Data Context Capture Assign Assign/Unassign Reality Data from a Project
Create Create Reality Data and assign them to a Project
Manage Manage Reality Data
Use Use Reality Data
PS Federated Connection Manage Access to PS Federated Connections ProjectWise Modify PS Federated Connections Modify PS Federated Connections (Create, Update, Delete)
Scenario Services   STAAD Create Solution Create Solution
Solution Create  & Archive Solution Create & Archive
Scenario Create/Update/Delete Scenario Create/Update/Delete
Scenario Run Scenario Run
View Result View Result
Project Insights Service Manage Access to View and/or Configure Insights ProjectWise View Project Insights Dashboard View Project Insights Dashboard
Configure Project Insights Dashboard Configure Project Insights Dashboard
ProjectWise Forms Manage Access within Issue Resolution and Forms Services ProjectWise View Gives user access to view forms
Comment Gives user access to comment on forms
Create Gives user access to create forms
Modify Gives user access to modify forms
Assign Gives user access to assign forms
Approve Gives user access to approve forms
Delete Forms Gives user access to delete forms
Manage Forms Gives user access to manage forms in Issue Resolution and Forms landing pages
Create Dashboards Create and edit dashboards for Issue Resolution and Forms landing page
Component Center Manage access to components within Component Center Component Center Read Component Center permission to read components
Product Settings Service Manage access to settings for Bentley iTwin-powered applications iTwin Manage Settings Allows users to create, update, or delete context settings
iModelDataManager Manage Access to Tag Management Applications PlantSight Read SharedQuery Read SharedQuery Description
Update SharedQuery Update SharedQuery Description
Delete SharedQuery Delete SharedQuery Description
Manage Briefcase Manage Briefcase Management Administrators Page
Edit Data Edite iModel Data in Queries
Set ReadOnly/Editable Column Edit columns as readonly/editable using column option in Queries
Export Queries/Folder Export Queries/folder from current project to selected projects
Set Advance Mode Set Advance Mode on in Queries
Create New Query Create New Query in Queries
Validation Service Manage Access to Clash Detection Design Validation Create Library Create Library
Delete Library Delete Library
ResultSet/ValidationSet Create/Update/Delete ResultSet/ValidationSet Create/Update/Delete
Model Run Model Run
Quantity Take-Off Configuration Service Manage Read and Write Access Controls for Quantity Rules SYNCHRO Pro / 4D Read/Write Configurations Allow users to upload and update QTO configuration
Read Configurations Configuration and apply it to models
iModel Schema Management Service Manage Access to iTwin Design Insights Schema Management iTwin Query Query Contexts
Upload Upload Contexts
Delete Delete Contexts
PdfGeoIndexingService Manage Access to PDF Documents SYNCHRO PDF Read Read PDF documents
  PDF Modify Modify PDF documents
SYNCHRO Manage Control to Synchro Modules SYNCHRO SYNCHRO 4d Access to SYNCHRO Modeler, SYNCHRO Open Viewer
SYNCHRO Control Access to SYNCHRO Control
SYNCHRO Field Access to SYNCHRO Field
SYNCHRO 4D Review Access to SYNCHRO 4D Review
Guest User Guest Permission for SYNCHRO
SYNCHRO Bid Access to SYNCHRO Bid
SYNCHRO Cost Access to SYNCHRO Cost
4D Scheduling Permissions Managing construction projects with 4D scheduling & simulation, model-based QTO, and construction modeling SYNCHRO Read Schedule Read SYNCHRO 4D Schedule
Read Schedule Actuals Read SYNCHRO 4D Schedule Actuals
Read Schedule Assignments Read SYNCHRO 4D Schedule Assignments
Read Schedule Costs Read SYNCHRO 4D Schedule Costs
Read Schdedule Resource Status Read SYNCHRO 4D Schedule Resource Status
Read Presentation Read SYNCHRO 4D Presentation
Read Documents Read SYNCHRO 4D Documents
Read Issues Read SYNCHRO 4D Issues
Read User Defined Data Read SYNCHRO 4D User Defined Data
Write Schedule Write SYNCHRO 4D Schedule
      Write Schedule Actuals Write SYNCHRO 4D Schedule Actuals
Write Schedule Assignments Write SYNCHRO 4D Schedule Assignments
Write Schedule Costs Write SYNCHRO 4D Schedule Costs
Write Schedule Resource Status Write SYNCHRO 4D Schedule Resource Status
Write Presentation Write SYNCHRO 4D Presentation
Write Documents Write SYNCHRO 4D Documents
Write Issues Write SYNCHRO 4D Issues
Write User Defined Data Write SYNCHRO 4D User Defined Data
Write 4D Project Setup Write SYNCHRO 4D Project Setup
ProjectWise Deliverables Management Manage Permissions for Sending Transmittals ProjectWise Read & Create Draft Packages View and create packages, view settings
Receive External Packages Receive packages from external organization
Issue Packages Issue draft packages, review & issue packages
Approve RFI Response Review and approve RFI response
Manage Settings Modify PWDM project settings
Document Registry Service Manage Control of Documents SYNCHRO Create/Modify/Delete Documents Create, modify, and delete documents
View All Revisions Access to all document revisions
SYNCHRO Bid Manage Access to Bid Management SYNCHRO Administer Procurement System Administer Procurement System
Read Project Bids Read Project Bids
Write Project Bids Write Project Bids
Read Project Procurement Contracts Read Project Procurement Contracts
Write Project Procurement Contracts Write Project Procurement Contracts
Design Insights Manage access to Design Insights, which provides project teams with analytics to understand the implications of design decisions iTwin
Manage User Settings Users can configure the following settings: Ancillary Data User Settings
Create Custom Dashboard Users can create custom dashboards
Edit Custom Dashboard Users can edit custom dashboards
Create Concept Comparison Users can create concept comparisons
View Template Users can view Templates
Edit Template Users can edit Templates
Design Validation Manage access to ProjectWise Design Validation for checking the completeness and quality of BIM data which is critical for reducing risk and generating actionable insights ProjectWise Approve Validation Script Approve Validation Script
Engineering Data Manager Manage access to tag management OpenPlant Create Tags Create Tags
Delete Tags Delete Tags
Edit Tags Edit Tags
Edit Properties Edit Properties
Manage Column Options Manage column options - apply at iModel
PlantSight Portal Manage access to functionality in PlantSight Portal PlantSight Dashboard Administration Dashboard Administration
Show Acquisition Show Acquisition
Show Aggregation Show Aggregation
Show Data Manager Show Data Manager
Show Documents Show Documents
Show Insights Show Insights
Show Issue Resolution Show Issue Resolution
Show Validation Show Validation
Show Visualizer Show Visualizer
Show Forms Show Forms
Machine Learning API Manage access to Machine Learning iTwin Design Insights Run Inference Permission Grants access to run ML inference jobs, default read-only
Labeling data in ML service Labeling data in ML service
Insights and Reporting Manage access to reports, which aggregate digital twin data from multiple sources into one unified format and place iTwin View Access reports in Insights and Reporting for a context
View/Configure Configure reports in Insights and Reporting for a context
SYNCHRO Cost Manage access to construction contracts, budgets, and change orders SYNCHRO Cost system administrator Cost system administrator
Setup cost contracts Setup cost contracts
Manage cost configurations and workflows Manage cost configurations and workflows
Data Manager Manage access to data OpenPlant Create Tags Create Tags
Edit Tags Edit Tags
Manage Column Options Manage Column Options
Release Tags Release Tags
Read Shared Query Read Shared Query
Delete Shared Query Delete Shared Query
Renamed Shared Query Renamed Shared Query
Export Queries/Folder Export Queries/Folder
Promote to Shared Query Promote to Shared Query
      Set Advanced Mode Set Advanced Mode
Extension Service Manage iTwin.js Extensions iTwin Manage Extensions Allows user to create and update an iTwin.js extension, as well as create different versions of the extension.
Other Language Sources
Deutsch
