| Version(s): | 10.11.00.115 |
| Area: | Survey |
When importing a text file into a new fieldbook, user receives the following errors:
Error occurred imporing File " TIW ASCII
SurveySendEvents: SendEvent
This is a known issue in the 10.11.00.115 release when a text file is imported into a fieldbook in a new DGN file that has not been used before. The workaround for this issue is to exit the product after the error is received, then open it again with the same DGN and re-import the file. Once the DGN is re-opened, text files will be able to be imported as normal.
