Video: Create Clipped Terrain Model
Product(s):OpenRoads Designer Connect Edition
Version(s):10.00.00+
Area: Terrain Modeling
This video demonstrates the Create Clipped Terrain Model tool from OpenRoads Designer Connect Edition. In the video, the process is used to clip information from a terrain model generated from a survey field book in order to isolate a desired location or area of interest as an individual terrain.
https://youtu.be/N0LwkMNgrzg
