Subscription Services Landing Page
1. Click the box to the left of the name to place a check next to the name of the Team Member you wish to modify
2. Assign Role(s) will enable. Click to launch the Assign to Role dialog box
3. Assign to Role dialog will launch
4. Add or remove roles from the Team Member
NOTE: A Team Member can have more than one role
5.Click Assign Role(s)
6. Clicking Cancel will quit the operation
7. Click Submit to add the role, or back to go to the previous dialog
Other Language Sources
